Only two are in the bag. Usually I find the bag descripion of contents to be correct, except they give us little "gifts" from time to time of extra rivets or screws or such. I am not sure if that is an actual error, or to allow us to drill out a rivet or toss a platenut that has no threads cut in it without having to order a new one. Of course many small items, including screws and nuts and washers are not in the plastic bags, but in a brown paper bag with a staple to hold the stuff in. Once you open those bags, you stand the chance of loss from the open bag, and you sure cannot count every washer or nut.
Inventory is a huge task really, especially of you get the whole kit at once as I did. I abbreviated the inventory, obviously you cannot count the 12,500 LP4-3 rivets to be sure you were not shorted, I sort of skipped over small parts count and concentrated on the expensive stuff. You would have to add a lot of time to building if you actually counted every last item. My faith in Vans was well founded, they make sure everything is there and properly packed, you will have to look very hard to find shortages..
