William Slaughter
Just fitted up the Infinity stickgrip to the stick and installed the assembly into the plane. I have an "S bent" stick and trimmed it to get the stickgrip as low as practical, but the clearance to the instrument panel is still minimal. The edge of the coolie hat switch is the closest approach at about 3/16". I might be able to trim another 1/8" max, but there is no way I can get enough to clear if I had my thumb on the switch. On the other hand, it seems unlikely that I would be needing to run trim while holding in a virtually full nose-down stick. Practical concern or not? Thanks.
