db8
Am figuring out the stick/seat/panel interface thing. Still have the emp on, but don't know how much the stick will move with the ailerons on. Can someone please tell me how far left and right from the center of the panel your stick moves with full scale aileron deflection till the aileron stops come into play? I have tried to measure the movement of the bellcrank , then apply that to the stick movement, etc, but I think the best way is to get this info is from an existing airplane. That would really help me out because my seat is larger than normal and I am having interference issues -- especially the furter away I get from the center position. I plan on having the stick come very close to the bottom of the panel (Infinity grip). So the best way is to move the stick full left while it is right under the lip of the panel, go vertical and measure the distance from the center position on the panel, plus the same on the right. I'm just looking for a ball park. Thanks in advance. Dave
