Alright guys, need a little advice here.......I have a wooden stick handle with a PTT switch in the center. Is there any way to add an autopilot disconnect switch to it or should I just use the PTT for the A/P disc. and use my panel mounted PTT's? I would like to have both on the stick if possible. Also, should I consider replacing the wooden one with somehing else?
