Does any buddy have an opinion on the best stick grips to use with Aerosport aftermarket panels?
On some installations I have noticed that the stick hits the panel prior to the elevator hitting the stop. That's a scary situation.
In others, If that's the case... have you cut the control stick, so the grip will clear?
There are many options available...I'm just trying to find the grip that, through usage has from a functional standpoint features you like and providers adequate clearance for full elevator travel.
Have some of you overbought grips with functions you never use? If so, what are the options on the stick that are most useful?
Appreciate any guidance you can provide..
Thanks!!
Thanks!!
