I am about to seal in the fuel sending unit on my tank. Bought the stewart warner float type from vans but was wondering if I should up grade or do these things work fine. They feel pretty cheap. Also I'm not very good when it comes to electronic stuff so bear with me. I assume there is one wire off the center screw and fuel guage connects between the line and goes to ground. Whats the easiest way to test it before I put it in. I am guessing to use an amp meter but where do you touch the probes? One on the center screw and one on tank? I feel like an idiot with such a simple task but that's the way it is.
Also, sealing it in, do you put proseal on both sides of rubber gasket or none at all, just bear gasket? How about the center screw on fending unit, is it already sealed with that little cork gasket? Just want to make sure everything that needs it gets it and vise versa. Thanks guys.
