vlittle
Vx Aviation is a frequent contributor (both financially and otherwise) to VAF, and I hope Doug will indulge us if we do a tiny bit of promo on this site, since it's relative to what we all do:
Summary of Announcement:
VICTORIA, BC---February 16, 2011---Vx Aviation today announced the
introduction of the first stereo audio mixers designed specifically for
experimental aircraft applications. The AMX-4A and AMX-4B dramatically
simplify and lower the cost of audio system installation in both existing
and new aircraft. Both units are virtually pin-compatible with the
industry-leading AMX-2A monophonic 10 channel miniature audio mixer,
introduced in 2008.
Both the AMX-4A and AMX-4B units provide five independent stereo input
channels. Three channels are fixed-level, designed to connect to audio
sources that have their own volume controls, such as EFIS systems and XM
radios. Two of the channels have screwdriver adjustable audio levels,
providing the flexibility required when connecting to fixed level sources.
Monophonic sources are supported by connecting together the left and right
inputs of any input channel.
The AMX-4A low output version works seamlessly with PS Engineering
intercoms, providing the 2 volt peak-to-peak input voltage limiting
required by the PS Engineering products. The AMX-4B
high output version has no such limiting and provides up to 12 volts
peak-to-peak drive capability and a gain of 15 decibels, making it
compatible with intercoms that require input amplification or for directly
driving headphones.
For more information, please see our website
For further inquiries, please contact me vern_little (the at sign) vx-aviation.com. Thank-you.
Vern Little
Vx Aviation
www.vx-aviation.com
introduced in 2008.
driving headphones.
![AMX-4A-4B-photo.jpg](/proxy.php?image=http%3A%2F%2Fvx-aviation.com%2Fphotos%2FAMX-4A-4B-photo.jpg&hash=425b8416c009c3ccfb73734e1a69ddcd)
Vern Little
Vx Aviation
www.vx-aviation.com
