stem valve
Guilhermepilot
I couldn't find a valve on my kit considering the nosewheel is tubeless I think I need to buy it, someone knows where?
Thanks captains
The standard Vans nose wheel requires a tube. It is available from Vans as part number "U LAMB TUBE" for $11.00. They are also available other places like Aircraft Spruce. Search around locally for a 11X4.00-5 tube.
If you have an aftermarket nose wheel it may be tubeless. The Beringer brand comes to mind.
Considering your other post regarding recent arrival of all kits, I would bet the tube is somewhere in your boxes. It is only slightly smaller than the tubes for the main wheels.
The tubes may be folded up (sort of triangular) in a plastic bag. Maybe inside one of the tires. Should be two there.
Bevan
Yeah, my nose wheel came with two tubes. The mains only had one tube each. I thought it was an error until I found out everyone else I talked to had also received two nose wheel tubes in their kits as well.
The tire says tubeless because it is capable of holding air and sealing without a tube. However the wheel must also be designed to seal without a tube, and the stock wheels are not. They need tubes.
You might want to give Vans a call. If you bought the package from them it might be a case of a packing mistake. If so, I bet they'll fix it.
