I have the SteinAir mid-console 30-position CB panel in hand. Does anyone who used this have any pictures of how they wired the backside? How they brought the main 14V supply to the assembly and tied it in?
I have the same panel but not sure what you are asking, some of the CBs are fed from my avionics bus and some from the main power bus so if you want minimum wires you would need at least 2 feed lines of sufficient gauge to the panel. If the CBs are separated by bus you can use bus bars to connect the like CBs together. The proper sequence is Power(bus) - CB - Switch - Device.
Leaving the panel you still need individual wires to each device. I have individual lines from the busses to the CB panel (30) and individual lines out (30).
Played around with it. Was thinking of having each row tie into a long strip with one screw per row to the main bar. Then measured and bent up the funny piece here. Benefit is it can screw down to the regular screw of the breakers one connection with per row. Might not t be an adequate connection??
The two on the right were playing around with the side bar main bus idea.
