Following Dynon's Skyview instructions, with unit warmed up but off I used a manometer to put a small vacuum on the static line and when I power it up I get a negative altimeter reading. I would expect a positive reading. Any comments would be appreciated.
Thanks Ron
Never mind I found my mistake. Both methods I used were pressurizing the system. You have to vent off the manometer then plug the lines to make a vacuum.
Thanks Ron
