Are people generally installing drain valves in the pitot or static systems? It looks to me like, any way you route the lines, there's going to be a low point in the system. Which, I would assume requires a drain valve in the event of condensed moisture. If so, does someone sell a prefabricated drain which can be easily installed? Or is there a way to install the pitot and static lines so they drain through the ports? At least with the pitot line, it looks like the drawings have it following the wing spar DOWN, and then, presumably, at some point it will have to proceed UP and into the panel.
