Flion and anyone else reading this.
READ THIS POST CAREFULLY
Do not assume your system is accurate just because you had your avionics checked by the avionics technician when you did your last AD Inst 8/9 or whatever you guys call it over there.
Your avionics as flion above points out above may be deadly accurate all the way to 20,000' and my Dynons were, better than the TSO'd Altimeter I have.
The problem is you are sitting in your hangar with a known static source testing your plane.
YOU ARE
NOT dragging a static on a drogue 100 yards behind the plane comparing a "True and Known" static with the static in your aircraft at speed.
If you are not 100% sure of what I am saying go ask some test engineers to explain it better. Kevin Horton on this site is a classic for explaining it, search his name and threads.
Am I making myself clear. In flight static is not the same thing as when you get your altimetry checked out on the ground and can yield very big errors as I found when doing our test flights.
Oils aint Oils
