I have noticed after installing both static ports (rivets) that the tubing attachment directions call for securing with clear silicone sealant. After letting dry over night both connections to the ports were not very secure. It appears the silicone sealant does not bond well to the tubing.
Have any of you found this problem also? I think it may be a problem trying to reattach these tubes later should they fall off or become loose.
Is there any reason we cannot use Aircraft Spruce static ports. They have a non slip tubing connection.
Thanks for your input.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
