Keith Williams
First, the "heads up". When starting on the fuel tank I noticed that the main skin has extra holes that are not on the plans. It turns out that these are for clips that are in the plans revision Vans made 11/21/11. My kit was shipped 12/12/11, but with new skin and clips but the old plans. So, I download the new plans, go to Office Max, have them printed on the proper paper and get back to work.
An hour later I'm prepping tank parts and have moved on to 37-05. Hmmm. The parts do not match the new plans (no large hole in the tank top). Fortunately I had not tossed the old plans pages. It appears that Van's has changed the method for assembling the filler neck parts. The flange and top skin I have go with the old plans, not the current version.
I do not know what combination of parts and plans I have here. So I just have to work my way through the old and new plans, identify the changes, and then check my parts to see which version I have. So that's the "heads up" for those at about this stage.
Now the "gripe". From years of working around manufacturing I know configuration and change management is tough, Van's is a lean organization and I can live with a some grief. My "gripe" is that on plans revisions Van's does not spend the few minutes it would take to briefly describe what has changed in the revision. I have written Van's about this and was told: "Like Jeppesen and many others, we've found that a simple print-and-replace is better than trying to track individual revisions.".
How hard can it be to write a sentence or two describing what changed with each plans revision? Based on what I know about the November tank change so far (don't know what else I will find), the sentence could read: This revision changes page 37-02, to reflect the addition of attachment clips and revised tank attachment bolts and pages 37-05 and 37-06 to correct the call-out of washers on the sight gauge and show changes in the installation of the tank filler attachment.
Now my "question". On 37-05 the instructions for the sight gauge say to remove a protective film from plastic the material. I have been picking at the corners with a sharp knife to get the removal started. Unable to get any thing to come loose. Material is amber colored and it looks like there is a film on it. Suggestions on removal? Or, maybe, the material has changed?
Keith Williams, Milan, IL
