I'm making progress, thanks to all of you. My RV6A doesn't have a starter solenoid and it has a key starter, Sky-Tec starter. It has been blowing the 10 amp fuse about every 4 or 5 starts. I'm told that I can put a heavy duty push button starter and that will solve the problem or I can add a starter solenoid. Anyone know if the starter cable is hot all the time even if the starter isn't engaged, it just waits for a ground to start. Is this a safety issue? I save weight if I don't add the solenoid and it keeps the firewall uncluttered.
Thanks!
Thanks!
