I only have 1/4" of stud sticking out of the starter flange on 2 of the studs. I suppose I could jam 2 nuts on to the stud and back it out, but then it would be loose and if I use lock washers on the nuts vs safety wire the the studs can back out. Is this a common issue? Any suggestions?
