How much current does the coil on a Vans start relay use?
lucky333 Well Known Member Jan 14, 2008 #2 Coil measures about 3.3ohms Figure on about 4 amps (more or less depending on battery voltage). Mine shows 4.15 A on a 13.8V supply. The battery voltage will be lower while cranking. John
