Very small amount of red 83282 hyd fluid near gear mount fitting on inside after two weeks. No air entered other than at reservoir and master cylinders are still both very firm.
Fuel smell in cockpit while setting avionics. Went right to the fitting in front of boost pump with a combustible gas leak detector and no boost pump. Turned on pump- 32 psi- one drop every four minutes. Tightened both one half of a flat. No red, blue, smell or electronic detection afterwards. My leak detector will pick it up way before you can smell it or see blue. It is going to have its probe in my tunnel on the first few flights. Find an hvac guy to come by and check all of your fuel tank joints and lines. Don't worry about fuel filler caps. You may also sense a little near throttle/mixture shafts at fuel servo. Anywhere else...investigate. Do this electronic leak check at every annual too. Just remember these are extra sensitive to find leaks before they get to the explosive limits. You must allow a few days for fumes to dissipate before rechecking a leak repair.
