Biil, stall fences do not lower the stall speed. The cuffed leading edge is what lowers the stall speed by allowing a higher angel of attack before the wing stalls. A stall kit normally has a reshaped leading edge and stall fences.
On the Cessna I had with a Horton stall kit, the stall progressed from the wing root to the wing tip because of the wing washout. The stall fence took the stalled air, as it went from the wing root to the tip, and dumped it aft so you had better aileron control near the stall.
RV's wings do not have any washout and stall all at once, not progressivly as my Cessna did. For that reason I don't think a stall fence will help. Possibly a redesigned leading edge could lower the stall speed, but most likely at the cost of top speed. I don't think most RV pilots would give up the higher cruise speeds for a lower stall speed. RV's are a great package as designed.
