bhassel
Steps 1 & 2 have you install the HS-1213A & HS-1213B hinge brackets to the Fwd spar. What it doesn't say is what the torque value is of the AN3-4A bolts going into the K1003 platenuts or the AN3-12A bolts used for the stops going into a AN365-1032 nut.
I believe that the later torque should be 20 - 25 inch pounds. However, I'm not sure of the torque value of the bolts going into the platenuts.
Bob
Bob
