The right Control Column Mount Assembly is riveted to the bulkhead, F-1203A. (page 21-11)
Following instructions on page 32-14, when I tightened the stabilator control cables, the tension on the Control Column Mount Assembly pulled the bulkhead aft, creating a bow of about 3/8 inch in the bulkhead where the assembly was attached. I had to loosen the cables all the way to get everything back in shape. My plan is to install the floor plates to give it more rigidity and then go back to tension the cables.
Anyone else have this problem?
