twvandusen
I'm New Here
Guys (and/or Gals),
I'm currently mounting the rear stab to the fuselage and, per plans, have leveled the fuse in both pitch and roll. I've drill the 4 forward spar holes successfully but when I check the stab incidence using the 3/16th inch spacer under the rear spar I find that the bubble touches the front hash-mark on the level. It requires almost another 1/16th inch spacer to make it perfectly level. I've rechecked the fuselage and it still is level. Should I:
a) Drill the holes in the rear spar and forks using the 3/16th inch spacer or,
b) Drill the holes using the additional 1/16 inch spacer in order to get it to be perfectly level again.
Thanks for your comments,
Thom
Thom
