Brantel
New 327 is installed and tested. Thanks to Stein for getting me one so quickly.
Hooked it up to the 430W so it will auto standby.
Thank goodness the tray has the same dims and bolt hole locations as the KT76A to allow an easy swap. I also got lucky since I had to pull the tray from behind the subpanel. Lucky for me there was enough room to get it out and the new one in....
Upside down under a panel making up harnesses is not my idea of fun! I ain't built for that!
