Is anyone using the spruce stainless antenna? If so, how is the performance. It sure is alot cheaper than the other options. It will be connected to the new MGL radio if that matters.
................ do yourself a favor now and buy a good Comant/DM/RAMI and never look back.
I could type on the subject for a long time, but trust me....
Stein
Mine is permanently mounted on the roof of my hangar, and we're both perfectly happy with that arrangement.....
All kidding aside, the antenna does work very well as a Comm Antenna - I used to have the same kind of things on my old Grumman, and they worked great. The problem with the simple wire whip is in getting a good "RF seal" with the simple connections (rather than a BNC/Coax connector). Frankly, it is hard to get a good connection that doesn't "leak" RF all over inside your metal cockpit. If you have a simple panel and equipment that is not sensitive to RF, you'll be fine. If, however, you have less robust gauges, LED indicators, and autopilots, you might have glitches every time you transmit, as you'll end up with RF bouncing around the cockpit.
That's the only reason I joke about wire whip - I started with one while the Val was still under construction, and after testing, changed it out for a better unit.
Paul
