Sportsman aerobatics, ratcheting harness ?
For those of you doing, or having done sportsman level aerobatics ( particularly in 8 ) do you use a ratcheting harness, or standard 5 way?
If you have a ratcheting, a aero, how uncomfortable , cumbersome are they for your normal flying?
For sportsman level , how much of a difference do they make?
I would recommend both a ratcheting harness and a dual lap belt. Sure, you're only doing Sportsman, which -- assuming you're not doing a separate freestyle -- is essentially all positive loading except for the momentary negatives on a couple of 45 degree lines (half cuban, sharks tooth, etc). But that assumes you fly all the figures correctly. What if you err on a figure? It's easy for unusual attitudes in aerobatic flying to end up with a) more loading that you expect, and b) negative loading, especially in a highly pitch sensitive aircraft like the RV8.
The ratchet is extremely useful for tightening the lap belt in flight. You can crank down the belts as tight as you think possible, and then after you've done a G check on base for your box entry, find after returning to upright flight that you can crank the belts down a lot further all of a sudden. The seat cushions, the seat pack portion of your chute, all that stuff compresses when you start pulling 4 or 5 G. The belts themselves even stretch.
When I flew the Pitts and Extra -- either with students or in competition -- I always tightened down the lap belts until it was almost painful. By the end of an intermediate or advanced sequence, they were usually measurably loose again. If I didn't have some bruising after a session of advanced practice, i wasn't tightening the belts enough. Most of those sequences were red, dashed lines.
Anyway, I think the dual belts are a huge boost for safety, and the ratchet just makes life much easier and more pleasant, regardless of what level you're flying. Just getting in and out of the belts is easier when you can rachet them closed and easily release the tension when you want to egress after a flight.
I've got a 5 point Crow in my RV-6 (single lap belt), and as nice as they are, I do miss the ratched and the security of the second lap belt when doing aerobatics.
--Ron
--Ron
I had a ratcheting harness for airshow work, which I quit doing at the end of 2015, and only recently removed from my 8.
I was so used so them that I never even thought about the little extra time it took to hook em up. I always felt so secure in them but since removing them it never crosses my mind.
Put them in, enjoy your aerobatics and never worry about bumping your head in turbulence.
Just my 02 cents worth.
