I will have two G3X 370's on the left and and avionics stack that will consume most of the panel's vertical stretch. At this point I will have no significant cutouts on rights side (ipad will go there). I have been thinking of splitting the panel in two pieces around the stack and using the structure laid out in the plans. I figured this would give me easier access in the future (currently spoiled from the 6A tipper). However, I see a lot of folks leave the panel as one piece. It would seem like a lot more work getting the panel off in that case, due to the radio trays. I plan to mount the GX23 into the sub-panel on the right side, so would need the panel removed to gain access to it.
curious about the pros and cons here and what others have learned from experience.
Larry
Larry
