I have a question about the proper length of the splice strip between the leading edge skin and the tank. I cut it to run from the aft edge of the top skin to the aft edge of the bottom skin with the result that it is in between the leading edge skin and the main spar flange and will be between the tank skin and the main spar flange. Is this correct? Looking at it now, it seems that it should run from the top aft edge of the inboard leading edge rib to the bottom of aft edge of the rib, short of the main spar flange.
