llavalle
I was at the "tap the tie down bracket" stage of my wings. I knew how to tap a hole, I've done it a couple of times before. Not that it's complicated but I've always found it awkward... A cheap tap will twist, you think it's going to break, etc etc.
My brother lent me a "spiral cut" tap. We started the cut with a regular 3/8x16 straight flute type. When a couple of thread were cut, we switched to the spiral flute tap.
Wow, what a difference. Instead of having to back up at each 2-3 turns, you screw it one way, all the way down the depth you want... then unscrew. The chips will go up through the flutes.
I'm told this tap is worth around $50 (cad) a piece... Not really worth it to tap 2 holes but if you can rent one, like I did, go for it.
