Spinner to Cowl Clearance Gap
RV12Roger
Active Member
I would like to hear 2 or 3 comments re the spinner to cowl gap dimension considering the vibration of the engine in the rubber motor mounts. I have installed the engine and have now started fitting the cowling. Doing so in this order allows me to fit and center the cowl better with the spinner.
I did it the same way. It was much easier to adjust the cowl to spinner gap that way than to guesstimate with the engine out. We ended up with a 1/8" clearance all the way around.
Spinner clearance
There have been several previous discussions on the forum regarding the advisibility of waiting to install the engine before fitting the cowls. Even though the scribe marks are accurate it only takes a small deviation at the fuselage junction to move the spinner end an ugly amount. The plans and the factory say that you should just cut the cowls to the scrib lines before having the spinner back plate installed for reference. But several of the early builders had difficulties getting good spinner clearance and based on this experience, I waited to have the engine installed to fit the cowl. There is really no reason to install it early unless you like to gamble.
Here are a couple of pictures, the first one is my final spinner clearance of slightly more than 1/8":
This may be unfair, but here is a picture, of the factory demo plane:
I don't know, but assume the factory demo cowl was fitted in plan sequence.
I think the plans should be changed on this, it is much easier to do the job after the engine is mounted, and will result in better clearances and eliminate redos which entail drilling out a lot of rivets and building fiberglass repairs.
As far as engine vibration in the mounts, the Rotax is pretty smooth especially with a dynamic balance done. I doubt if vibration of the engine in the mounts would be an issue if the spinner clearance were even less than 1/8", but 1/8" looks good and gives a bit of room for installing and removing the cowls.
Tony
Plate behind the prop
Th pice behind the prop look like a aluminium sheet, not like in the plan from cut out pice from the spinner
Sorry swissguy
Daniel #120383
Thanks for the response
Backing up the hinges inside for drilling might be a little tricky - but worth the effort for good alignment.
Good thoughts in your response - can move ahead with confidence - thanks.
Spinner/ cowl Gap
I taped paint stir sticks to the front of the cowls as I was setting them in to get the right space. It never varied and came out very uniform.
So here is some history regarding RV-12 cowl installation.
The photo Tony posted was when the prototype airplane was only about 4 weeks old, based on the date on the photo (it was probably shot at Sun & Fun).
It was still very much a prototype. It had a research and development certificate of airworthiness and it was hauled to S & F in a trailer.
It had a pre-production cowl, and spinner, and cooling radiator duct, and... well, you get the point.
I can not think of what the cause of the spinner missmatch was (it might have even been that the engine position had been shimmed for some flight testing reason, I don't remember).
The airplane as it sits now with 700+ hrs on it, has a spinner that aligns with the top of the cowl.
I am right now in the middle of doing the first condition inspection on the TeenFlight RV-12. It's cowl was installed by teenagers using the before engine is mounted process described in the manual. It's spinner is perfectly aligned with the cowl (I don't have photos, you will have to take my word for it).
Historically, cowls on RV's have been installed after the engine is mounted, using the spinner back plate for reference.
A LOT of builders have still mess it up using this process. Even builders of RV-12's have messed it up while aligning to the spinner (with the help of scribe lines on the cowl).
The manual was written in an attempt to help people get a satisfactory installation without a huge amount of fuss. Someone that is willing to fuss with it, can probably do a bit better, at the cost of more time.
Bottom line...
I believe the current process works if the builder carefully follows the plans.
Installing the engine first also works, but does not assure success (I know of RV-12's built this way and they had engine to air duct interfearances and other problems, so it should not be considered a silver bullet).
The manual is not likely to be rewritten for the reasons already mentioned. The engine first process does not insure that a builder will end up with a good fit, any more than the current process does.
The best over all answer is... There is many different ways to do most building tasks. The manual can only give one. If you think a different way would be better for you, that is of course your choice.
