Spinner Question
Bdflies
Active Member
Friend
Hi all,
I've got an RV-14a with EXP IO390-119 with Hartzell HC-C2YR-1BFP prop. This is the 'Blended Airfoil Prop'. Currently have the Vans supplied S-601-1 spinner. I understand that flange to cowl face is essentially the same across the Vans line, so don't limit knowledge to the 14 only.
Does anyone know if the Hartzell polished spinner kit will replace the S-601 spinner, without cowl modifications? I understand that the spinner back plate and forward mounting will have to be swapped, but I really don't want to start modifying the cowl. Has anyone made this swap and can comment?
Thanks in advance!
