bsacks05
Help! My RV9 is finished except for the spinner and I discovered a problem. My Ed Sterba wood prop is 4 3/8 inch thick at the hub, but the space between the forward and back spinner plates is 3 11/16. A difference of 11/16 inch. The manual says that if you encounter this situation you need a smaller front plate. From where? Anyone have this problem or have a solution? I may be able to get a little more space by sanding the inside of the spinner and also reducing the thickness of the front plate. I put an email into Van's and am waiting for the reply.
