Jim P
I have a Hartz. BA prop and am in the process of working the spinner install. From what I can see, most folks install the back plate, then mount the prop on the engine, THEN drill the backplate for nutplates.
Is there any problem with mounting the backplate and pre-drilling all the nutplates while the prop is off the engine. Then go back and match drill the spinner to the back plate after prop is mounted. I'm just seeing a major PITA with de-burring while that prop is on the engine and I only want to install it once for now.
