I am helping a new RV10 owner get the annual done on a recently purchase US built RV10 so he can pass the MDRA inspection for a canadian C of A. One of the concerns is the builder has the cowling built to close to the spinner that it is actually touching on the bottom right side.
The cowling has a groove wore into it from the near 300 hrs of flying it has.
I sent this question in to vans and never got a response. Hopefully you folks can give some suggestions.
On the RV10 the first thing I noticed is the back plate of the spinner is rubbing on the cowling. The plane has close to 300hrs but I really do not like the idea of leaving it as it is.
The first thing that came to mind was placing a large washer between the engine and the rubber mount to push it ahead 1/16 or so.
The other choice would be to trim the back of the back plate down of there was room to the nut plates.
And the last choice would be to take the washers out of the forward side of the spinner back plate that are between it and the prop, requiring the back plate to be trimmed on the inside to clear parts of the prop hub.
What is the best fix beside redoing the cowling?
