How about this for customer service?
I received an email direct from Hartzell in response to my previous post.
The key to using the template is the blade centreline......
- Print the template, ensuring the scale is correct
- Cut out the template from the printout using the zero-clearance shape.
- Mark the blade centre lines on the spinner (I used the rivet pattern on the rear bulkhead to identify the 180 degree spacing)
- Lay the template on the spinner, aligning the blade centre line you marked on the spinner (which you can see through the paper) with the template blade CL and hold/clamp in place
- Mark the outline of the template on the spinner
- Cut and file the cutout
- Repeat for the second cutout
- Now trial fit spinner to the prop/spinner rear bulkhead and fine tune the hole shape
- Take a cautious approach, keeping the cutout hole size to the minimum until after you've finally located both bulkheads to the spinner.
- Best to get the rear bulkhead finalised first then the front bulkhead
- The template assumes that only the spacer is fitted between the prop hub and the rear bulkhead. If you add any washers to the spacer then you will need to take account of this in the cut-out.
- Take care to check whether the back edge of the spinner is "true". The rear bulkhead, centred on a small turntable, can be used with a plumb bob to confirm the correct placement of the rear bulkhead within the spinner.
- If your spinner is like mine, the rear bulkhead will fit inside the spinner leaving approx. 1/8th inch of the spinner projecting behind it.
- Note that the point on the template where the Blade CL crosses the "Bottom Edge of Spinner Dome" reference line needs to align with with the back edge of the rear bulkhead flange. This is obviously rather tricky as, when you are first positioning the template on the spinner, you don't know exactly where the back edge of the flange will end up. I'm going to use the actual back edge of the spinner in the first instance and extend the shape after trial fitting.
- When finalising the front front bulkhead position you may need to use washers under the bulkhead to move it forward or else build up the inside of the spinner with fibreglass to meet the bulkhead.
- Once all is said and done, make sure there is no chance of the blade touching the spinner. You don't want any marks or damage on the root of the blade. There are posting elsewhere on VAF talking about methods of exercising the propeller pitch mechanism
One further note. If/when the propeller is serviced, it may slightly affect the location of the front bulkhead screwholes, which might need to be ovalled out sideways a bit.
I hope this is helpful to others. I know it has helped me. I cannot praise Hartzell highly enough for their responsiveness and customer service ethic.
