Spinner/Cowl Clearance?
Pounder
Sponsor
Hey gents, forgive my intrusion: Does anyone know off the top of there head what the gap/space clearance is, if called out, for RV-8 Spinner-to-cowling?
BP
1/4.” Mine is less but they don’t rub against each other. It requires care though when removing the cowling.
J.Baker
RV8
I can’t remember what the build manual explicitly said for my 7 but I built it at a little over 1/8 and never had any issues. If you planned a lot of acro then that plus sag over time may get it closer but that’s addressable with mount washers and/or new mounts.
I never noticed any appreciable sag over 10y and maybe 800h- little acro tho.
On my 10 have it at exactly 1/8 which is per the construction manual. 200h. Hasn’t budged.
Ultimately it’s a tradeoff between ease of maintenance (cowl R&R) and efficiency.
The closer the better. As long as it doesn’t rub. Big gaps not only slow you down they also affect cooling efficiency.
Prepare for the pages of people that will say you need 1/4-1/2” to get the cowl off. Not so. You can slide a thin bit of plastic cut to shape down the gap to protect your paint while you do it if you are concerned.
DWG 48, top middle
1/4 inch, i made a wooden spacer, worked perfectly
If you have the engine mounted, give it a few good yanks up, down and side to side. I thought that I had my cowl spacing and height good, but the plane's jostling trip on the back of a truck from my garage to the airport resulted in a new resting position for my engine, and the spinner is now about 3/16" lower than originally planned.
1/8th of an inch
Painters tape on the back of the spinner provides scratch less cowling removal. RV-14A. Good luck, and good suggestion on giving it some pulling up and down. I cannot run the engine with just the bottom cowling on.
There’s a few good threads floating about on gaps.
Somewhere there’s a shot of the bevel to place on the cowl just behind the spinner to aid in R&R.
Van’s Demo Aircraft gaps:
RV-7A .180”
RV-14A .200”
RV-10 .250”
Just data points. Interesting to note as the HP and/or engine length increases, the gap increases.
