hevansrv7a
My -7A was built - in my mind - to go a little faster than "stock". I used SJ cowl, plenum and all three wheel fairings, omitted the steps and have only com and transponder external antennas. Until now I was disappointed. My max speed at altitude was 174 kts (200 mph) and that was with more than 2700 rpm on my Prince prop.This was a good increase from 155-56 without the fairings.
Craig Catto and Sam James said I should be going faster. Van's said they don't believe in the SJ stuff and that I was doing OK.
Long story short - I realigned one of the main wheel fairings which was out a couple of inches as measured about 2' aft of the rudder.
Today told the tale. I gained about 6 or more knots. No other changes were made. The TAS on the GRT is calibrated and is within 1 kt IMHO.
Effective pitch before varied from about 72 to 75 over a large number of observations. Today it averaged 78.These three readings in ktas are at density altitudes 3560-3840.
2500 159 67%
2700 174 86%
2770 180 94%
The best it would do in similar air (cold!) a few weeks ago was 6 or even 8 knots less.
Based on prior experience, the numbers will be a little better at 8000 to 9500. I'll be anxious to see what my re-pitched Catto 3-blade will do.
2500 159 67%
2700 174 86%
2770 180 94%
