You mean if you ignore W&B?
With 100 HP, at 1800 lbs gross weight, the top speed would be about 175 mph, which sounds OK until you consider that rate of climb would be about 400-500 ft/min.
This is assuming you could get the CG to come out right...it's designed around an engine weighing close to 300 lbs.
