I had a dud spark plug appear the other day - caused me to pretty quickly turn back and land when things turned very rough after setting up for cruise. After pulling the plug on cylinder 3 (which showed much higher EGT as compared to the other cylinders) I saw that the insulation was broken away, so I just replaced both plugs since the other didn't look great either. They were most recently replaced over 300 hours ago so I will probably just replace all the rest of them anyway.
Anyway, there's a couple of things happening all at once
* Replace the plugs (~$300)
* The 500 hour magneto inspection is due (~$1000)
* I am considering replacing the wiring harness, since it's a little rough-looking and might even be original to the plane. ($400?)
Would anyone actually recommend doing this work, or instead doing the work to switch away from Slick magnetos?
I could instead:
Put in P-mags, with the added benefit of being able to use automotive plugs.
Or, an alternative such as getting a system32 EFII, which I expect is a much more expensive proposition but gives:
* More HP
* Fuel injection, no more carburetor and carb heat.
* Automatic mixture control
But, I also need backup power, since I only have the 1 battery+alternator (EFIS has its own backup). This would be a nice addition anyway, since having the GPS, autopilot and radio have backup power would be helpful.
What have others done in this situation?
I could instead:
* More HP
