Any that read above 5000 ohms, throw it out.
Measured how? This might be a dumb question but is this measured between to center connection terminal and the tip or i it measured elsewhere.
Doug Gray
RV6 flying...
Gary,
What's the hole diameter? That tool seems like something fairly easy to make unless the hole is some funky size.
greg
Keep them gaped and cleaned regularly and test each one with an ohm meter whenever you remove one. Any that read above 5000 ohms, throw it out. Also if you ever drop one while handling it on a cement floor, pick it up at once and drop it again on purpose,,,,then throw it out. You should get engine TBO if cared for properly.
Gary,
greg
Inspected spark plugs today on Lycoming O-320, previously swapped plugs from bottom to top at 50 hours. Now at 100 hours inspected again. All four bottom plugs have lead balls deep inside. Cleaned, reinstalled, didn't notice any changes in engine performance.
