WingsOnWheels
Per the plans, the center seat ribs are placed with the web 2" off centerline (going from memory). My pre-drilled spar also has one of the big spar bolts dead center 2" off centerline.
How have other folks delt with this interference? I have a newer fuselage kit that came with the lightening holes in the seat ribs already cut out so making the hole smaller is not an option.
The ribs came from the factory already notched to clear the splice plate leaving about 1/2" of web material between the notch and the lightening hole.
This is only a problem on the upper splice plate since there is ample material at the lower splice plate to increase the size of the notch.
Pictures would be appriciated.
Here is a picture of the removeable rib, you can see the upper notch I am talking about. Other than this rib being split, this is pretty much how it came from the factory. The fixed sister rib on the other side of centerline has the same notches.
![FP16052010A00046.jpg](/proxy.php?image=http%3A%2F%2Fwww.kitlog.com%2Fphotos%2Fproject_754%2Ffull%2FFP16052010A00046.jpg&hash=64dad0ec8643d6cba741cb7bc3fdd9f4)
