Before I modify the wrong work bench for a back rivet plate and kick myself later: I have no idea of the size of parts that can be back riveted and how much room is necessary. I have one permanent 2' deep bench that is up against a wall and one about the same depth that is open around all sides. I'd prefer to use the bench against the wall, but not sure if the wall will be a problem if there are big/awkward parts.
Will a bench against a wall make dealing with parts difficult, or are most parts that lend themselves to back riveting small enough that a 2' bench against the wall is ok? (building a 9)
