alfonso hernandez
Member
Hello, dear members,![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Someone can help me with some photos or explanations abouta the connection of manifold pressure sendor for DYNON.
The pressure port on the
manifold pressure sensor requires 1/4? inner diameter tubing for a
secure fit. You may need to use adapters to convert down to smaller inner diameter tubing for your specific engine. We recommend that you use pipe clamps at every transition point, including at the sensor itself.
Best regards from Spain.
