Frank, what is your propeller spec? FWIW, I believe your numbers are quite typical from other reports Ive seen. Do you believe the prop twist (speed limit) is the problem here (is the engine capable of higher rpm)?
The way I see it, the recommended engine/prop combination should be able to consistently meet cruise speed specs as a minimum target, and possibly be capable of a bit more speed when conditions warrent. Ive had the suspicion for a while that 160hp might be a bit shy of fulfulling the 9's full design aspirations.
Quick Dynon question- is it possible to program the aircraft's actual speed "colors" into the display?
