For those of you who riveted your wings solo, did you have them vertical in the jig, or flat on a bench? Particularly interested in bottom outboard skin.
Also, did You use Vans pattern (Inboard to outboard, somewhat L pattern), or entire aft spar first, or something else altogether?
Had great help on top skins. Solo on bottom inboard, which really was not an issue. Now planning how to do outboard bottom so I can hit the ground running when I get back to the shop.
Thanks!
Thanks!
