Solid to pop rivet
dirtybirdy80
I'm New Here
There are a few of the AN426 3-3.5 solid flush rivets that I need to replace with a flush head/countersunk pop rivet.
Can anyone tell me which flush pop rivet can be used in its place and where they can be purchased?
Head angle different
Isn't the driven rivet head angle 100 degree while the pulled rivet is 120 degree?
No problem with a new hole as it can be dimpled to the 120 degree size from the beginning, but if used to replace a previously driven solid rivet it will probably sit much lower in the dimple.
JMHO
