Are you suppose to solder the coax wire to the SL30's 90 degree connector ?
Wicked Stick Well Known Member Nov 20, 2008 #1 Are you suppose to solder the coax wire to the SL30's 90 degree connector ?
Sparky Well Known Member Nov 20, 2008 #2 Yes. Use standard 60/40 solder and only apply as much heat with the soldering iron as necessary to form nice solder joint.
az_gila Well Known Member Nov 20, 2008 #3 Just sent you... ...the Garmin picture in regular e-mail.... gil A
