A little more info. I here of people that talk about the use of big guns for soldering and being a no no. Well if you regulate the power, that's why I like the Wellen. Cold gun, when you take and put it where you need it, like under a panel, you end up on your head, taking your gun along when it's cool is real nice. It has a light. You get into possision and sqeeze the trigger and it's HOT, I like that one. Now you don't need to put it on the wire and wait and wait, if you have a big gun you pull the trigger and ZAP! it's hot now, you can touch the trigger and hit it on and off to make the perfect temp. You can hold the gun away from the wire a little and let the heat go UP to the wire and make it work also, so remember that one, put the heat on the bottom of the wire to be soldered and the solder in from the top or side. Oh here is one, put solder on the tip of the gun as you are heating it, will double the time it takes to get the wire hot, but make sure the solder comes in from a 90degree or 180degree to the tip on the wire for proper soldering when it's ready. There is no need for fancy equipment, just give me a Wellen gun and some GOOD solder. I like RadioShack part. no. 64-009E it's .032dia Rosin-core and 60/40. Don't forget the heat shrink, very important.
