Soft Start wiring tips. Page 46-13.
BigJohn
Installed the soft start harness today. This was a retrofit for me, since almost all stuff "under the hood" had been previously completed. Tough to get at the "A" and "B" connectors to insert the new pins. Had to remove the electronic ignition modules in order to get at the connectors to disconnect them.
The instructions didn't warn me about the little rubber plugs in the unused pin holes in the connectors! Guess what - the pins won't go in until you remove those. Found the best way to get them out is to push a 1/16" drill down through from the top.
Used Loctite and re-torqued the module mounting screws to 22 in/lbs.
