Tbone
I'm finally fitting my cowl with IO360 180hp Superior and the snorkel. My goal is to have the filter as far back as possible on the ramp and somewhat centered left to right in the opening. After doing the necessary notching for alternator clearance I have a "good" sight picture of snorkel placement. Unfortunately it is too far outboard (about an inch) and could go back about 9/16 to 5/8. I have succumbed to probably cutting up the snorkel to fit those dimension areas. I could possibly leave it as placed but not sure if I will have the outboard clearance necessary. Also it is forward enough to be blocked somewhat by the cowling inlet lip. I believe I read on the forum (Dan) that the inlets should be trimmed short for better airflow. That would be ok to do but not sure how much to trim and if I need to leave the inner screws as shown for strength or just omit the aft screw and trim straight. This pic off internet is similar to what I'm talking about.
I plan on working on the ramp and leaving it long until I need to trim and need feedback on ideas and options. I also think that the drawings for the snorkel install are not very clear as far as the filter install. Does it just slide under front edge and rest on snorkel and held in place by just the two side retainers?
Here is pic of my setup.
![m90d8h.jpg](/proxy.php?image=http%3A%2F%2Fi67.tinypic.com%2Fm90d8h.jpg&hash=a091abc2a23db5ec3b922906f8e39dd8)
![20azdi0.jpg](/proxy.php?image=http%3A%2F%2Fi65.tinypic.com%2F20azdi0.jpg&hash=8e81dd7e5898f2a3ab3a76955441a2e0)
![sfyscz.jpg](/proxy.php?image=http%3A%2F%2Fi68.tinypic.com%2Fsfyscz.jpg&hash=3b8cf24437c4b47f071a23c8d369fc2e)
