Djgeib
Active Member
I have an IO360 in a -8 with a superior cold air sump and Vettermans crossover exhaust. Unfortunately the aft hole in the air sump is directly above the crossover pipe. It was obvious that the sniffle valve Vans supplied would not fit in that spot so I order a manifold sump drain from Airflow Performance. I’m still having clearance issues. I can get the valve in but attaching a drain line to run aft rubs on exhaust. My choices seem to be move to the forward hole (not ideal for tail dragger) or remove drain line and let it drain straight down.
Any thoughts, tips or suggestions?
![IMG_0194.jpeg IMG_0194.jpeg](https://vansairforce.net/data/attachments/32/32809-1e9c684ca555b92a5c9970d4d02037aa.jpg)
![IMG_0192.jpeg IMG_0192.jpeg](https://vansairforce.net/data/attachments/32/32810-1f48552be96b02ff1b97899cda0ec1a8.jpg)
